First some boring basics.
For all examples mentioned in here, we are using 8 Bit signed values.
The uppermost Bit indicates the sign:
0 = positive,
1 = negative.
With 8 Bit, we have a range of -128 to +127:
binary hex decimal ^ 01111111 0x7f +127 | 01111110 0x7e +126 | ... | 00000010 0x02 +2 | 00000001 0x01 +1 0 00000000 0x00 0 | 11111111 0xff -1 | 11111110 0xfe -2 | ... | 10000010 0x82 -126 | 10000001 0x81 -127 v 10000000 0x80 -128
Problem is, when subtracting 1 fom -128, we won't have -129.
The result won't fit into 8 Bit, so the value would roll over to +127.
Also, when adding 1 to +127, it won't fit into 8 Bit,
giving us -128 as a result.
The main purpose of the V_Flag is, to indicate that such an overflow had
happened:
The signed result from add/subtract did not fit into 8 Bit (for our example),
and the sign Bit became corrupted.
Strange thing is, that the flag, indicating this Overflow
is called V in some microprocessor's datasheets,
instead of O.
Don't know, why... beats me.
Now some examples for the 6502:
'.' means V_Flag cleared,
'*' means V_Flag set.
Hexadecimal values, carry inactive.
Column + row, Bit 0..3 always zero.
Example: 0x70+0x10 would corrupt the sign Bit and set the V_Flag.
A+B, D_Flag=0, C_Flag=0: +0123456789ABCDEF + 0000000000000000 00................ 10.......*........ 20......**........ 30.....***........ 40....****........ 50...*****........ 60..******........ 70.*******........ 80........******** 90........*******. A0........******.. B0........*****... C0........****.... D0........***..... E0........**...... F0........*.......
Hexadecimal values, borrow inactive.
Column - row, Bit 0..3 always zero.
Example: 0x80-0x10 would corrupt the sign Bit and set the V_Flag.
A-B, D_Flag=0, C_Flag=1: +0123456789ABCDEF - 0000000000000000 00................ 10........*....... 20........**...... 30........***..... 40........****.... 50........*****... 60........******.. 70........*******. 80********........ 90.*******........ A0..******........ B0...*****........ C0....****........ D0.....***........ E0......**........ F0.......*........
Note, that CMP does not affect the V_Flag on the 6502.
For the NMOS 6502, it looks like the V_Flag seems to ignore
the BCD_correction, so it won't work well in decimal mode.
[HOME] [UP]/ [BACK] [1] [2] [3] [4] [NEXT]
(c) Dieter Mueller 2005
