Baud Rate generator
Uart clock has to be 16 times faster than the Baud Rate.
For instance, 19.2 kBaud would require that CLK = 307.2 kHz.
Divider factors for some common crystal/oscillator frequencies:
 18.4320 MHz -> : 60
 11.0592 MHz -> : 36
  9.8304 MHz -> : 32
  9.2160 MHz -> : 30
  7.3728 MHz -> : 24
  6.1440 MHz -> : 20
  4.9152 MHz -> : 16
  3.6864 MHz -> : 12
  2.4576 MHz -> :  8
  1.8432 MHz -> :  6
And if the application doesn't require to _exactly_ match the Baud Rate,
there might be some other interesting frequencies...
4 MHz divided by 13 gives 307.6923 kHz, what is ca. 0.16% off from 307.2 kHz.
Note: The UART clock doesn't need to have a 50% duty cycle...
Example for using a 3.6864 MHz TTL oscillator:
It's also possible to build an 8 Bit programmable divider with two 74163.
Another approach would be tapping with a 74151 multiplexer into the
outputs of a 74393, if only a few different Baud Rates are needed.
The most primitive approach is using a jumper to select the Baud Rate,
as shown in the example above.
Also note, that there are a few examples in the Internet about how to
configurate the Baud Rate of UARTs that are integrated into Microcontrollers...
PICs, for instance.
[HOME] [UP]/ [BACK] [1] [2] [3] [4] [5] [6] [7] [8] [9] [NEXT]
(c) Dieter Mueller 2007
