MEMORY PLUS Manual By Lee Davison
Page 6
POWER
The power requirements for MEMORY PLUS are simple and on-board regulators are
provided to make powering the board even easier. Essentially the board requires
only +5 volts at about 2.0 amps. While the actual current requirements will
vary slightly with the particular components on any board1 the table below
shows the individual and collective power requirements.
Component # Typ. Max. Meas. Max. Meas.
Total Total
74LS00 1 8 3 8 3
74LS04 1 8 4 8 4
74LS32 1 5 10 2 10 2
74LS138 3 7 10 6 30 18
74LS367 3 14 24 17 72 51
2716 4 57 105 45 420 180
6522 1 50 [A] 60 52 60 52
2102L [B] 32 14 22 14 704 448
2102L 32 14 22 14 704 448
Total System 2016 1206 [C]
Notes: All current values in milliamps.
[A] Value as estimated by an engineer at MOS Technology.
[B] 2102Ls are split into two sections of 4K RAM each in the table for
purposes of discussion below.
[C] Measurements were taken with an inexpensive meter and should be only
used as a guide to the system current requirements.
[D] The above values were obtained with Fairchild 21L02s. The values
may vary with other 21L02s produced by other manufacturers and
supplied with your MEMORY PLUS board.
Regulated +5 Volt Supply. If the MEMORY PLUS is to be powered by regulated
+5 volts, then the supply should be connected to pins E-21 and E-Y on the
MEMORY PLUS expansion connector. The supply should be capable of supplying
at least 2.0 amps in addition to any other board it is driving such as the
KIM-1. The Reader at the top of the board should be positioned so that the
bus wires are away from the top of the board and the Header notched corner is
positioned at pin 9.
Unregulated +8 to +10 Volt Supply. If the MEMORY PLUS is to be powered by
unregulated +8 to +10 volts, then the supply should be connected to pins
E-19 and E-20 on the MEMORY PLUS expansion connector. The supply should be
capable of supplying at least 2.5 amps. This supply is distributed to three
+5 volt regulators which each handle a separate section of the board.
Regulator Q4 supplies the high 4K of 2102L RAM with 448 to 704 milliamps.
Regulator Q5 supplies all support chips, the 2716s and the 6522 with 310 to
608 milliamps.
Regulator Q6 supplies the low 4K of 2102L RAM with 448 to 704 milliamps.
The. Header at the top of the board should be positioned so that the bus wires
are near the top of the board and the Header notched corner is positioned at
pin 1.
Page 6
Last page update: 8th December, 2002. |
e-mail me
![e-mail](../../eml_sm.png) |
