MEMORY PLUS Manual By Lee Davison
Page 24
MEMORY PLUS Parts List
ITEM PART Qty. DESCRIPTION
1. U1, U2, U72 3 IC 74LS367 Hex Bus Driver with 3-state~outputs
2. U3, U4, U76 3 IC 74LS138 3-to-8 Line Decoder
3. U5 1 IC 74LS00 Quad 2-Input Positive NAND Gates
4. U6 1 IC 74LS32 Quad 2-Input Positive OR Gates
5. U74 1 IC 74LS04 Hex Inverter
6. U7 - U70 64 Memory Element 2102 450 nanosec, low power
7. SW1, SW2 2 1-of-7 Rotary Switch
8. R1 - R3 3 Resistor 3.3K, 1/4 watt
9. C1 - C37 37 Capacitor .01 MFD, 50WV DC
10. C38 1 Electrolytic Capacitor 22 - 25 MFD, 25V
ii. C39 1 Capacitor .001 MFD
12. C40 1 Electrolytic Capacitor 3 - 5 MFD, 35V
13. Q1, Q2, Q3 3 Diodes 1N4001 Rectifier 50V
14. Q4, Q5, Q6 3 voltage Regulator LM340T-5, +5V, 1.0A
15. Q7 1 voltage Regulator LM340T-24, +24V, 1.0A
16. HS1 - HS3 3 T220 Heat Sink (Large)
17. HS4 1 T220 Heat Sink (Small) (may be omitted)
18. S1 - S4, S7 - S70, 71 IC Socket 16 pin
S72, S76, S80
19. S5, S6, S74 3 IC Socket 14 pin
20. S71, S73, S75, S77, 5 IC Socket 24 pin
S79
21. S78 1 IC Socket 40 pin
22. H1 1 IC Socket Header 16 pin
23. U78 1 VIA 6522 Versatile Interface Adapter
Accessories Package
24. 3 Connector 44 pin (dual 22)
(NOT included if a Cable has been ordered.)
25. 3 Battery Clip 9V transistor battery type
NOTES:
1. The Memory Test is adapted from "Memory Test" by Jim Butterfield
which appears on pages 122 and 123 of THE FIRST BOOK OF KIM, edited
by Butterfield, Ockers and Rehnke, published by Hayden Book Company.
The book sells for $9.00 and is a must for any 6502 user.
2. The program listings in this manual were produced by the Micro-ADE Assembler
on a KIM-1 with a MEMORY PLUS board. The COMPUTERIST version of Micro-ADE
includes a cassette tape with two versions of Micro-ADE. One has the program
in 2003 to 2FFF and uses 3000 to 3FFF for the Source and Symbol working areas.
The other has the program in C000 to CFFF and uses 2000 to 3FFF for the Source
and Symbol working areas. This second version is ready to be placed into
EPROM and left resident in your MEMORY PLUS board. Micro-ADE costs $25.00 for
the Operators Manual and Cassette Tape. This Manual includes most of the Inputi
Output Source Listings so that the user can customize the package to his type
of terminal. Complete Source Listings are available for an additional $25.00.
Page 24
Last page update: 8th December, 2002. |
e-mail me
![e-mail](../../eml_sm.png) |
