MEMORY PLUS Manual By Lee Davison
Page 8
RAM Memory
The Random Access Memory (RAM) used with MEMORY PLUS is 2102-type static RAM.
Each 2102 chip contains 1024 bits of memory. Any single bit is directly
addressable. By addressing eight chips in parallel, an eight bit word is
accessed. It takes eight 2102 chips to provide 1024 8-bit bytes. The
MEMORY PLUS provides 8K bytes of' 8-bit RAM (actually 8192 bytes). This re-
quires 64 2102 chips: eight chips per 1K times eight K.
The 2102 chips used with MEMORY PLUS are synertek 21L02B or equivalent.
This version of 2102 has the following basic parameters:
SPEED: 450 nanosecond access time
POWER: 30 milliamp worst case (these are "low power" chips)
single +5 voltage required
The MEMORY PLUS RAM is organized into a single contiguous 8K block of' memory.
The location of the RAM in the MICRO addressing space is defined by a switch
which may be set to start at any 8K boundary (2K hex boundary). Looking at the
board with the regulators at the top, the RAM select switch is the left switch
of the pair of rotary switches. Using the flat side of the switch as the position
indicator, the addresses are set as follows:
4 4
6 2 E 6
On-board Address Select 8 RAM Not Selected ROM 8
Switches for RAM and ROM
A E 2 A
C C
The address associated with each position is:
2K 2000 to 3FFF Assumed as the RAM address in this manual.
4K 4000 to 5FFF
6K 6000 to 7FFF
8K 8000 to 9FFF
AK A000 to BFFF
CK C000 to DFFF Assumed as the ROM address in this manual.
EK E000 to FFFF Not normally used for RAM since interrupt vectors
must be defined in FFFA to FFFF if this memory is
addressed. See note in EPROM Memory about using
this space for EPROM.
The exact layout of the individual RAM chips may be found in a diagram in
the section on "MEMORY PLUS Testing and Field Repair".
Page 8
Last page update: 8th December, 2002. |
e-mail me
![e-mail](../../eml_sm.png) |
