Name ATkey_01 ; PartNo 00 ; Date 19/03/01 ; Revision 01 ; Designer Lee ; Company ; Assembly None ; Location ; Device g16v8as ; /* This GAL is the select logic fot the AT keyboard interface board */ /* Logic minimisations None */ /* Optimizations None */ /* Download JEDEC/POF/PRG */ /* Doc File Options fuse plot, equations */ /* Output None */ /* *************** INPUT PINS *********************/ PIN 1 = A4 ; /* address bus */ PIN 2 = A3 ; /* address bus */ PIN 3 = A2 ; /* address bus */ PIN 4 = A0 ; /* address bus */ PIN 5 = A1 ; /* address bus */ PIN 6 = p02 ; /* CPU phase 2 */ PIN 7 = RW ; /* read write */ PIN 8 = !SEL1 ; /* block select */ PIN 9 = !SEL0 ; /* block select */ PIN 11 = A6 ; /* address bus */ PIN 12 = A5 ; /* address bus */ PIN 13 = A7 ; /* address bus */ /* *************** OUTPUT PINS *********************/ PIN 19 = !KBR ; /* key port read strobe */ PIN 18 = !KBW ; /* key port write strobe */ /*PIN 17 = ; /* */ /*PIN 16 = ; /* */ /*PIN 15 = ; /* */ /*PIN 14 = ; /* */ /* intermediate terms */ ADDR = !A7 & !A6 & A5 & !A4 & !A3 & !A2 & !A1 & !A0 & !SEL0 & SEL1 ; /* F120h (0010 0000) /* Output terms */ KBR = ADDR & RW & p02 ; /* key port read strobe */ KBW = ADDR & !RW & p02 ; /* key port write strobe */
