I hate imposing on anyone to do what I used to be able to do on my own.
I definitely feel that. I hate imposing on others in any possible way. But, there is a time and season for everything in life.
One thing that was confusing to me was BDD mentioned the solder that was already 'printed' onto the board, but then he used solder paste as well. Are BOTH needed? I had thought it was only the solder paste that was needed. I also found it interesting that so much turned into so little (relatively). It's like it nearly vanished, minus the few bridges that resulted.
What you are referring to is the reflow that the PCB house applies to exposed, bare copper. The usual reflow alloy, if not building to RoHS specs, is HASL, which is a near-eutectic tin/lead alloy, approximating 63/37 solder (be sure to specify HASL if you are manually soldering your creation). During reflowing at the point where liquidity is achieved, the solder carried in the solder paste will combine with the HASL to form the finished joint, ideally producing a nice fillet where the pin meets the pad.
JLCPCB uses HASL, that's the default option, and I have used it for each of my boards. So then, my boards are potentially already ready for SMT parts using solder paste + oven? I don't need to tell JLCPCB to do anything different than they have already done for my 10 other boards?
gloves like the kind your proctologist wears while probing your nether regions.
Eep! A time and a season for everything in life, it seems.
So, part of my interest in this topic started when I watched Dave's latest video, an update on the X16 (here
https://youtu.be/nyByDNQuMMI). He showed how they assemble the VERA daughterboard, all SMT parts. Place the components, pop it in the oven, presto! THEN he showed how they are trying to quickly assemble the motherboard with all DIP parts. He uses a huge solder dipping station, which basically just holds a ton of molten solder in a bath with nails coming up out of it. They place the board on the nails and the machine dips the board in the liquid solder. Thing is, the extreme heat immediately warps the board and they are still having problems getting it to work correctly.
Which then is best, SMT or DIP? Makes me wonder, if the X16 won't be sold as a solder-it-yourself kit, why still have DIP-only parts?
